no its a stupid idea....2k will get you some really nice wheels..painting the stockies black will just look like exactly that..stockies can look ok if you lower your car right and put some spacers in so they fill out the guards a bit better..painting them a diffferent colour rarely makes them look any better..usually worse
you dont have to spend 2k on wheels anyway..full set of rotas can be had for 1k and look the business or, learn to ebay.
Just remember Stance is more important than rims..putting 2k rims on a car that isnt lowered right will just look like ass and you would be better offf with stockies..
Arts get off ya high horse mate.
Op- there is nothing wrong with painting the stockies, its a great thing to do, especially if you are on a budget. Make sure you take the time to do a quality job tho. If done rite it looks fine, but at the end of the day they will still be stockies. It will be fine until you can save up enough to get some good quality after market ones.
Good luck
Adam
They did so much wrong it's not even funny, I bet their paint is cracked and peeling now.
I dont see what they really did wrong...its like 4 simple steps. I basically did the same thing and my wheels are still freshly coated with clear after almost 8 months.
They didn't chemically bond the layers, and they didn't show or mention any mechanical bonding either, though they may have done that off camera. At 8:03, that spraying technique is terrible, he is spraying like a 14 year old graffiti artist. The other bloke has much better control and technique using the gun.
what do you mean by chemically bonding the layers?
When you spray, you shouldn't let the paint dry between layers. If it does, you need to sand it back to create a rough surface for the paints to mechanically bond. This will never be as strong as a chemical bond, which is where you let each layer dry to a tack before spraying the next layer. This means all the layers will dry together, creating a chemical adhesion that is much much stronger than just a mechanical interlock.
Back on my High horse here but....
it can look ok if you paint up some GTR rims or something and they are painted PROPERLY...
but painting the standard rims black looks shit..if you have shit rims to begin with painting them black will NOT solve the problem, they will still look shit..
now dont get me wrong it is ok to have standard rims as it keeps your car looking stock which is cool, but painting them black is not making it look any better at all, unless maybe your car is black and your trying to be super stealthy...:ninja:
they say you cant polish a turd and while you can paint one, a painted turd is still a turd
I've seen black stock rims on a white car which looked good, I've got silver stockies on mine which I'm happy with for road use, stock rims are good for a lot of reasons.
Paint them black, doooo iiiiitttttt
+1 ^
Artz, I don't know what you're on about mate. Standard R34 GTT wheels are not baaaad looking, they may not be as eye catching as a nice set of Jap wheels but they still go alright. Especially when painted black. When they are unpainted they look like standard wheels. When they are painted, they do a good job of setting the car off.
I mean this:
Compared to this:
It's a no brainer.
I agree with Hanaldo on this, makes the job much nicer.
If the paint on the rims to begin with is alright, then u dont neeed to primer them then paint them as such, if u use a light grade scotchbrite and scuff the wheels up and give them a good coat of paint (2-3 layers) then that should be easily suffficient. havent had any problems with doing that (and thats been on the bodywork of my old skyline which lasted me a year with no issues what so ever)
Just my 2 cents :thumbsup:
+1 ^
I mean this:
Compared to this:
It's a no brainer.
Perfect example. Seeing the difference is almost motivating me to do mine :blush:
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
