  • Replies 203
I dunno tbh.
2JZ is a drop in and go and has bigger valves etc
1.5JZ means building shit/modifying the head/block etc and I'm lazy these days
2JZ-GTE with new rings and bearings seems like the go to me
Turbos and manifolds finally off...I really feel sorry for Toyota mechanics
Lots of oil/grime on the bell housing and the back half of the block, might be leaking a little from the cam covers, the bolts were a little loose so nipped them up and I'll keep an eye on it.
Also have to figure out how to get the factory oil drain off...cant get a socket in there nor can I can a spanner in there....
I was expecting 2 drain holes in the block ala RB26...but its a steel Y piece...So I may block the rear one and use it as a crank case breather/oil return from a catch tank and use the forward drain for the new turbo...Should work well I think.
There are also the matter of the rear turbo water feed sticking out near where the new dump pipe will go, So I'll loop it into the front turbo water feed, which will be a neater solution to sticking a couple of bolts in cut off hoses...looks shit and tends to leak after a while.
Anyway a few photos of progress...Was delayed a little as a had to rescue one of my cats of the neighbors roof lol.
I'm quite happy with how it went today, only took 30-40mins to get the rear turbo off (just needed a couple of nuts removed though as most of it was done Monday)
I dunno tbh.
parts all interchangeable? like manifolds and turbos? and stuff?
loom?
mmmmnah I'll be right...Have seen a 1UZ-FE in a sprinter though ;)
fits alright, less room than it looks lol
love the 1uz swaps - its one of my projects down the line lol
i would like to see that.
then click the link :P
http://www.driftworks.com/forum/drift-car-projects-builds/58737-1uz-ae86-aus-toy.html
Chris you have more room in the bay either side than the Soarer does!!!
The front rails sit so high in the Soarers that where the engine sits is half as wide as the bay!
How are you going to fit dump pipes with the turbos like that? Are they adapters?
Did it take you long to get the intake vacuum lines all back on? there are about 9000 of them!
Well, some good news. Due to me having what looks like a 2 1/4" mid pipe I was going to try and make one...BUUUUUTTTT aftermarket ones for JZA80s are exactly the same :D
Also had a go at starting the dump pipe (the back half of it) by cutting up an old one I had here off the skyline...but it was all rusty and I ran out of grinding disks...so i decided to weld it up anyway....WHAT A MESS!!!! I wont make excuses. it wasnt cut straight enough and I got a bit carried away...really need a drop saw, as trying to cut angles with a 4" grinder just doesnt work!!!! >_<
http://www.driftwork...86-aus-toy.html
liking the red piping...
and.. wow. the amount of effort needed to make things fit..
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
