  • Replies 203
hahah I'm going to try and do it period mod, So it looks like it was wrapped in a bubble in 1997 or something.
So something along the lines of an old school Jap turbo kit (td06H-20g anyone :whistling: )
We shall see, what happens, it has a built A340E and a 3k(ish) stall, so next year sometime I'll drop a 5 speed in it get some big brakes on the front and get into some track work again.
Going to keep this one nice and simple (re: minimal mods) and tidy it up...and the most important thing
DRIVING THE BLOODY THING!
tl;dr? sub 300kws, brakes, drive
yeah or that.
I figure that if I keep it VERY simple I should be right lol
I wasnt planning on selling the Soarer...but this was too good to miss :thumbsup:
Also means I no longer have to keep an eye on my105 for a cheap as chups track car as I'll just use the supra
Back to the Car - I originally thought that the Twin Turbo R wasnt all the much different to the regular JZA70, I initially thought that all it got was much lees weight, recaro seats, momo wheel and Bilstein shocks.
Turns out it also has bigger anti-roll bars and stiffer springs, Now the Bilsteins are long gone (now has KYB's) No plans to change those just yet, as this car will well and truly be a case of if it aint broke don't fix it. May even save a thousand odd bucks on the brake upgrade and throw some track spec pads at it and see how it goes.
so no more soarer????
Still here being picked up just after xmas...did yours sell or are you parting it?
brake rotors and pads first, dont be one of ''those fanboys'' that think they need brembos to be fast.
brakes are pretty average standard, 300x22 with a single piston caliper
Dont fit
There is/was a kit out there that used R33 Gtst Sumitomo calipers and a 324mm rotor, was looking at pics of the kit yesterday and in all honesty it looks rubbish
Wilwood do a kit for under a grand using 330x28mm disks and their forged superlight calipers.
Not a huge fan of the cheaper wilwood calipers, so may buy the hats and get a thicker rotor and their better caliper and have bracket made to suit.
Just stumbled across this pic
I knew the 1JZ had short rods, but not this short
1JZ-gte rod and piston on the left and 2JZ-gte rod and piston on the right, 2JZ rods are shorter than RB30 rods too btw
1jz rod is 125.25mm, and look how solid the thing is! So any plans I did have of rebuilding the 1J down the track just got a whole lot cheaper :D
1J and 2J pistons also have the same pin height, so they are interchangeable but the piston crowns are slightly differernt
wow that's a short rod, the 1j rod looks alot thicker than the 2j rod too.
the piston skirt looks a little different between the two.
Edited by tweety bird
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
