Finally purchased my own TIG machine after borrowing one for a few months, so hopefully with time permitting i'll be able to get into making alot more stuff.
First up is the new exhaust manifold, after working with a mate at my other work we 3D modelled the 6 into 1 merge collector in Inventor. Split that down and make a flat template or the cuts for each collector.
unfortunately i didnt take pics along the way but with a hand grinder i've cut out and welded up the collector - its not perfect, unfortunately, but it should still flow much better than the china stainless manifold im using at the moment.
i'll work on making up a JIG to cut them out accurately when time permits. just had to test it out.
https://www.sau.com.au/forums/topic/380963-craveds-fabrication/
  • Replies 87
Nice work Chris. Do you have a mill handy? When I made my collector I used an indexing head/chuck and angled the head whatever degree merge it was I wanted. Actually I think it was about half of what I wanted. Cant remember now lol.
What merge angle did you run with? Around 15-18 degrees?
Yeah I bought my tig 3 months ago and it's already paid for itself so I can see what you mean will be following this closely to see how it turns out cause u have inspired me :-)
once u make ur jig what do u plan on making the manifold out of ?
Just steam pipe?
Yeah would be interesting to see what sort of prices you have to pay to do it yourself ;-)
And is there any reason ur using butt joins instead of beveled? Would get a nicer stronger weld with beveled
But just curios not criticizing :-)
All the best with it
Butt weld elbows are already beveled
as GTR81 said, the bends are bevelled, i'll prob radius the ends of the straight tube before i weld it up too
not sure when i'll get it finished, next step is working out where i want the turbo to sit. this will be going on my 26/30 which im still building so i'll have to find some references to help me position the turbo
trying to build it all out of the car then drop it all in in one go.
When I did mine, I tacked up the turbo flange with some rods to hold it where it needed to be so it cleared strut tower and what not when in the bat. Once that was done the rest was done out of the car on a dummy head. I did have to test fit it a few times during tacking of the runners to ensure clearance and whatnot, once that was good it was go for gold!
One thing I did learn was once you have everything tacked up and you are about to start welding it all, make sure you have a good solid base mounting plate for the head flange to bolt to so it doesnt want to warp. Say some 100x100x6mm wall. Then try and tig as much as you can while its all fully tacked up, except where it meets the flange and collector. Then break off the tacks holding the runners to the collector and flange and finish them off and then refit them and weld them on in such an order as you dont stuff yourself for access to other areas.
I may or may not have made some silly mistakes like that when I made mine, but hopefully you can learn from that!
Hopefully your manifold will turn out alot better then mine mate!
^^^^ some good ideas there r33 racer ...
Even tho you bolted the main flange down did it still warp a lil??? did u have to get I machined flat at all or we're u good to go ?
Do u u have pics mate ?
The more and more I talk with u boys bout it the more I wanna DO IT :-)
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
