hey, putting my stagea up for sale again, tuned to 306rw hp, mods listed below
hypergear atr43 ss-1, jjr bellmouth dump, single cell cat, hks high power cat back, jjr return flow intercooler, k&n panel filter, splitfire coil packs, 18" black pdw fuzion rims, tow bar, full set of floor mats, blue leds in climate control,
feel free to ask questions
0413533586 located in ipswich
pics up later.
https://www.sau.com.au/forums/topic/381108-1999-black-rs4s-12000/
  • 3 months later...
The pistons are cp 86.5mm 9.0:1, reason for rebuild was a small crack in the number 1 cyl ring land.
Here is a run down of what I've purchased for the build. Cp pistons, nismo engine mounts, oem timing belt kit, oem water pump, king bearings, crank collar bush, arp head studs, oem gasket kit, 1 new intake valve, spigot bush, clutch fork boot.
Maching costs were as follows - head $650, block $650, crank/other prep $850.
Muff - i replied in your thread.
Ok it's all running beautifully. Over 170psi across all cylinders. Currently still on run in oil and minimal boost.
Still for sale.
If not sold before the tune, price will go up a bit to reflect on all money I just spent. If sold before the tune and it doesn't make over 250kw for you i will pay for your tune.
Edited by lilcrash
  • 2 months later...
  • 3 weeks later...
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
