CAR:
Nissan Skyline Ti
1989 Model
White
RB30E
5 speed Manual
EXTERIOR:
White with colour coded bumpers and trim.
Towbar
Tinted windows
INTERIOR:
Fully optioned Ti interior
Velour trim and seats
Power windows
Power mirrors
Power steering
Cruise control
Full trip computer including instant fuel usage, fuel till empty, total travel time etc, etc.
Ice cold air con that has just been re-gassed
Aftermarket gear knob
Aftermarket steering wheel
Viper alarm, immobiliser and keyless entry
STEREO:
Sony CD player
Front and rear aftermarket speakers (can't remember brand sorry)
12inch MTX sub
WHEELS & SUSPENSION:
Lowered heavy duty king springs
Front 17 x 8 Koyo Drift Teks
Rear 17 x 9 Koyo Drift Teks
DRIVETRAIN:
Heavy duty clutch??
5 Speed Manual
ENGINE BOLT ON:
Pod filter
Aftermarket exhaust
Notes: The car is in really amazing condition! New thermostat, and rear brake pads and tie rod end. Fantastic and reliable car. No RWC or rego, would need rear tyres for RWC. Only bad points of car is the gearbox has a bit of bearing noise but it has been like this for a long time and is giving no signs of giving up any time soon! Love the RB30 reliability!
Price: $3500
Contact Details:
Phone: 0421471592
E-Mail: [email protected]
MSN: [email protected] (I am always available on MSN so feel free to add me)
https://www.sau.com.au/forums/topic/381120-1989-nissan-skyline-r31/
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
