HI guys,
I own a 2003 v35 coupe 6mt. Lately I've been having issues with my brakes, a gushing/grinding noise has been coming from the front left side brakes. I attributed it to wearing pads, so I took it to midas this morning and the told me that everything will need to be replaced. Rotors, pads and since they're brembo everything will be pricier. He quoted me $1,300 for everything. How much would rotors and pads be by themselves?
Thanks in advance guys,
Luke
https://www.sau.com.au/forums/topic/381338-v35-brake-service/
Contact GSL Rallyspot a forum sponsor on here for pads and rotors, not hard to find as he has his own section. I would say an educated guess would about 400-500 (I might even be wrong) for new front rotors and pads to suit. As for labour it shouldn't be more than 1-2hrs
Hmmm
Sounds a bit worrying, its always good to get a second or even third opinion.
The trade is quiet @ the moment in places so they may be trying to pull the wool over your eyes. If its just sounds your hearing and not feeling anything through the pedal it may just need pads, so your thinking is right. Have a look @ the rotors thru the wheel; do they have a lip or grooves or any other strange markings? The rotor should be smooth, but if they are glazed, they may need a machine or the very least a few firm stops to take the shine off them; providing all else is ok.
It may not even be the pads making the noise; we had a guy here who had a similar problem on his car, and it turned out to be the backing shim of the disc rubbing.
Food for thought :banana:
The Brembo disks are extremely hard and will require a carbide disk cutter, mine only cost $20 each to machine so hopefully they are ok. New Brembo disks are expensive but you can get aftermarket ones cheaper.
It may just have a rock caught behind the disk so definitely get a second opinion. Where are you located?
I have a front OEM Brembo rebuild kit here if you need one.
Interesting. When I took the car to Midas, the "mechanic" told me the discs were completely worn through and were too thin to machine? He was more than likely trying to upsell me to the moon. I'll make an appointment to see a brake specialist and see what he says.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
