I have a pair of hks gt ss turbos for sale... They are used but in awesome condition.... These turbos have done bugger all km's as there is next to no shaft play.... Side to side or in out! I need these gone ppl. $1700 ono comes with the hks actuators. Reason for sale is I'm gonna chase 800- 1000hp and these just won't cut it. They will make 600hp plus apparently. They are very responsive and they pull awesome through the whole gear. My loss your gain. Very clean turbos..... You will not be dissapointed
https://www.sau.com.au/forums/topic/381487-his-gt-ss-turbos/
Hey mate.
These are great turbos indeed, but infact are actually only rated to ~560hp and real world results on the dyno thread have shown these to be at thier limits at around the 340awkw (450hp) mark, the response & midrange is great making these the perfect turbo for street use according to some but i think 600hp+ is abit off the mark.
Anyways thats my 2c GLWS mate.
Yeah but you suffer more of a loss being four wheel drive yeah? So if you make 350kw at all four its about the same as 400kw rear wheel which would work out about 540- 560hp right..... I have seen somewhere someone making 600hp with these turbos in a thread somewhere I'm sure of it!
Im certainly not an expert in 2wd to 4wd dyno results difference but everything ive read in Drivetrain & Transmission Section points to the direction of 20-30kws tops and not a percentage like most people have been lead to believe.
Although most results have been with 98Ron & e85 has changed things up abit...
And then there is this.....Today, we are going to take a look at the smallest turbocharger currently offered by HKS, the GT-SS.  Officially, HKS rates the GT-SS turbo for 280ps, which is roughly 276hp.  It is worth noting that HKS power ratings are indicative of wheel horsepower, rather than flywheel horsepower.  In practice, the hks gt-ss has been shown to develop as much as 320ps, or around 315hp.  HKS currently offers the GT-SS in various engine specific packages to make installation and bolt on affair.  All GT-SS kits come with all required gaskets, bolts and fittings.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
