Still for sale! had 3 or 4 interested parties, but no follow through. Somebody please take it away! In love with my STI now :P
Edited by thychiz
  • Replies 40
Bump - Sorry guys but anyone who has JUST created an account purely to message me will be viewed as a little suss. Bad experiences in the past.
I have to give you credit mate. You've held a perfectly cool head about this the whole time. Thumbs up.
P.s. I'd say you're having a hard time selling to existing members as... well we all have cars, that's why we're here. If we did want to get a new car though, it probably wouldn't be non-turbo auto. =/
I'd hate to point out the obvious, but your target audience is P Platers.
Anybody looking for a sweet ride for their little brother/sister? ;)
Seriously though, I'd probably start giving those new accounts the time of day - they may just be a 17 year old who has never owned a car (hence first post on SAU).
Best of luck mate! I have a little soft spot for the GT as my friend owns one. Two white R34's going down the road looks nice, regardless of aspiration type. :)
Heh, yeah hanging in there mate :) Reason for being so cool and sticking it out is because I brought my 07 STi before even putting this up for sale, So there's no rush hehe :P
I see my biggest problem with sale being that its a non turbo, and here in WA we don't have P plater turbo laws. So very few new drivers go for the non turbos when they can just dance all the way to the bank and get a GT-T lol. But so far the 3-4 people that have seemed genuine all wanted it for their missus, So my target demographic is now teh females! Brb taking shirtless pics laying on hood.
Only if you were a little closer lmao, would take a long time to drive back to syd from wa :{
Pay to have it trucked to you, I'll knock a bit off the price to compensate :P
Edited by thychiz
Hey man mates looking for one in melbourne pretty much what he wants just wrong state, would you know a rough price of gettin it down here?
Hi mate, An estimated quote from a few places I found on google ranges from 600-800 Perth to Melb. Obviously this isn't exact but it's a fairly accurate estimate. Just depends which company you/your friend choose to go with. Let me know if you have any further questions :)
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
