hi im wanting to respray my car..
atm its yellow and ive been getting quotes to respray the outside for $3500 cash at rod bowen smash in blacktown.
has anyone got work done there before?
is that a good/fair price..
or i was thinking of changing the colour completely to a 2 tone black roof with sunburnt orange.
if theres any1 could reconmend a place in sydney or someone that would be interested in doing it.
thanks
https://www.sau.com.au/forums/topic/381523-respray/
3 and a half sounds quite cheap, but it also sounds like a window in job, and everything is taped up, i dont think and of the doorjams would be done either or the engine bay so u would still be stuck with the yellow paint being on the inside also. (not sure if they quoted to do the doorjams also but be careful)
if your looking for a decent job, windows out and door jams done be prepared to pay around the 7-8 thousand mark as an approximate, this can include any dents u may have in the vehicle, this still wouldnt include the engine bay tho unless the engine is already out.
all prices do vary from shop to shop so go around and see who offers what and see if u can work out a good deal by working of the shops to see who can do the best for you.
hope this helps in your search for a new paint job (if u have any Q's feel free to pm me):thumbsup:
https://www.sau.com.au/forums/topic/381523-respray/#findComment-6085693
hey man if you want give me a call i can hook you up with my mate from 2sus custom resprays to give you a quote his painted all my cars and done a great job on all of them and he has reasonable prices
let me no if your intrested
https://www.sau.com.au/forums/topic/381523-respray/#findComment-6087529
$3.5k wont include door jambs, but you shouldn't really need them done if you're keeping the car the same colour. These areas don't fade as there's no sunlight to bleach the paint. As buzz350 said, you'd be looking at around $8k for a colour change. There's heaps more stuffing around in removing and refitting panels/doors/glass etc
https://www.sau.com.au/forums/topic/381523-respray/#findComment-6087563
Just for refrence I picked up my 32 last week with a single change in colour.
I paid $10k (door jambs done, windows out and NOT the engine bay). But being in the ACT you get the high cost on most things..
Captive market without to many shops you would take your car too.
https://www.sau.com.au/forums/topic/381523-respray/#findComment-6087597
  • 3 weeks later...
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
