if your a DIY guy it looks pretty good , just needs a finish off panel over the battery area
good to show it doesnt take a fortune to make good sound , just a good selection and install.
where did you mount your tweeters ? are they the titanium models ?
hints
the box would sound better if it wasn't symmetrical a "close to perfect square" box has too many standing waves that cancel out the bass a bit, a little pillow stuffing /poly fill on the back wall of the box would improve that wthout reconstructing the box. it is sealed I hope ?
the box didnt need to come out so far, you could have used the space behind the panel better.
that metal trim on the box can cut the hell out of you or items in the boot... round it off a bit maybe paint it black to vanish , it stands out a lot... looks like a roadie box for band equipment a bit
do you have plastic panel on the amp take a load set on top of it ? or do you have a strong cover ?
does the amp have room to breath in the heat ?
Edited by Carbon 34
hints
I have been in the car audio business since 1992 " Ground Pounders Car Audio" in fact I was one of the first Lanzar dealers. So yes I never build boxes like this small sealed square yes I have poly inside. There might be another .25 sq ft of space behind the box. I was looking for the lightest possible setup. Tweets are in the factory spot on custom brakets just couldn't cut anything in this car it's one of 33 here in the states that's legal.
And the aluminum trim was to match the looks of the amp and speaker to reflect light in the dark with the amps blue light I never put anything in the trunk but a 1/4"plexiglass cover is going over it but I have to drill the vent holes in it first.
I see your a bass addict I built the loudest car in the central USA in 1998. 2000 watt class at 164 db. Honda Civic with eight 15" subs.
Edited by Weapon X
Where did you work ? I'm from central USA - Denver and used to build a lot of dealer demo cars for Sema, and CES. and been in the12v industry since 87
No, mines bigger :nyaanyaa:
no Im pretty sure mine is much much bigger..lol and weighs a lot more even with the whole boot install made out of carbon fiber and alloy
I was curious about where he worked to see if we crossed paths in a past life..lol from the looks of it its winnipeg canada. BURRRRRRR damn cold up there
Im sure some of his clients used to buy gear from us in the us and drag it back into canada to save the taxes. when I lived in Montana in 91 they would fill a truck up and drive it back over the border.
so being in canada you would have noticed my car is in this septembers Performace auto and sound mag page 158 ? and why do all the super hot chicks live in canada lol
My shop was in the middle of Missouri from 1992-2000 I give up on selling audio to all but friends. I was at the Lanzar partys in Tulsa Ok in 93-94. Talk about Super Hot chicks remember that blonde they hired to walk around and pose....WOW. She was in all kinds of pics and poster back then for all kinds of stuff.
What do you think about my head unit?? I've had it since 95 and one more. I'm just oldschool or just old. My son is building and selling audio setups now. I also have the last set of USD hand formed fiberglass A60 wave guides.
I have always built custom homes since I was a kid so that's what I still do more money. I'm not sure if anyone makes real money in audio with Ebay around.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
