Laptop MUST SELL URGENT... Make an OfferItem Specifics - PC Laptops
Brand: Dell Condition: New
Processor Speed: 2.4 GHz Chip Type: Intel Pentium 4
Hard Drive Capacity: 20 GB (may have a 60 gig soon) Memory (RAM): 512 MB
Screen Size: 15 inches Primary Drive: DVD+/-RW
Features: 10/100 LAN Card, Carrying Case, Modem, Operating System, USB
Next to NEW Inspiron 1100, Only used to watch movies and i have no need for it any more, it is only about 3 months old if that and still has the 3 year warranty.
This is a great fast reliable PC and comes with all the original Dell CD's including Windows Xp Home and MS Works.
No scrathes marks or impurfections what so ever,
Battery Lats about 3 hours when contactnly using and about 5 hours when not using at all.
Other Software is availiable on request.
This was upgraded from the original product that only had, 256MD Ram, 14" Screen, 10 G HDD this was bought for $2499, selling due to incoming bills and not needed any more
For further information please call me on 0410 635 901 or email at [email protected] or [email protected]
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
