Actually - I did loose my license coming home from EC on Thrsday - I must have gotton a bit carried away there and on Brabham drive, went round that round about near the Pitt Stop Tav, and they were waiting for me. Got done for over 30 kmph. Then when I was driving to the cop station, my engine blew up again. Got it towed to UAS but they were closed - so I ring John up and he doesn't want to have anything to do with it anymore. Fark man I am sooo pissed.
Anyone know what I should do ???
Abo bob can't use it till next week, I had it last night, but I have given it on to benm... not too sure if we will ever see it again!
Benm told me last night on ICQ that his work has this new ultra high res scanner and printer thingy with laminater - they got it got in their marketing department - Anyway, he said he would scan in the VIP license and print out a few copies. So anyone who looses theirs can get a new one.
Cheers to Benm.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
