Cheers guys! NISSAN PARTS GARAGE SALE
Hey guys clearing out the garage so have collected a heap of car parts (mostly Nissan) over the years. Deciding to get rid of some of it. A lot of good quality, useful parts all going ridiculous cheap! :ph34r:
So grab a bargain guys! some rare parts in here as well, you'll pay twice (and the rest) for these at a wreckers! May discount on some items so feel free to offer and will give discount for multiple item buys! :eek3:
So look at what is there if there is no picture for it let me know!
Parts all in Mount Gravatt, South Brisbane.
Please don't hesitate to text me on 0419761510 to find out more information or organize a time to come pick up!
R33 GTS-T PARTS (rb25de/t)
- R33 quarter (1/4) front guard/panel - $50.00
- R33 skyline (S1) passenger seat - $ 40.00
- R33 gts (non-turbo) rear brake calipers and lines - $50
- R33 gts (non-turbo) rear brake rotors (suit 4 stud, set)- $30
- R33 rb25det brake filler bottle $10.00
- R33 quarter panel indicator (right side) - $10.00
- R33 Smart Entrance box – FREE
- R33 roof handles x 4 - $10.00
- R33 dash vents near windscreen x 2 $5.00 each
- R33gts-t front passenger sear seats (great conditions includes rails) - $5
- R33 skyline jack and tool set – $20
- R33 boot gas struts - $10
- R33 fuse box and loom (has fuses and relays - $10.00)
- R33 wiper motor- $20.00
- R33 OEM throttle body (no TPS) - $30.00
- R33 rear interior trims, good condition - $20.00
- R33 front sway bar - $20.00
- R33 interior side pillars (seat belts go into them) pair - $10.00
- R33 stereo/gear surround - $10.00
- R33 genuine floor mats - $10.00
- R33 Manual Dash, 120XXX k's - $20.00
- R33 B-Pillars Pair - $10.00
- R33 accelerator peddle - $10.00
- R33 castor rods - $10.00 pair
R32 GTS-T/GTR PARTS (rb20de/t)
- R32gtr rear rotor (single) - $20 (slotted)
- R32gts-t rb20det OEM throttle body - $20
- R32gts-t rb20det coil pack brackets x 2 - $20
- R32 full hi-has set up $20.00
- Rb20det charcoal canister - $10.00
- R32gts-t rear cradle supports – FREE
- R32gts-t rear tail shaft (center – diff) x 2 - $10 each
- R32 front sway bar - $20.00
- R32 front indicators (some broken mounts) - $20.00 pair
- R32 coilovers (Rears 2 x Gabs adjustable coils, Fronts 2 x Blisteins coils, stiff enough to drift) - $200.00
- R32 gts-t rear reo bar (bent slightly on driver's side, still useable) - $20.00
- R32 gts-t passenger side front guard, in primer, straight - $50.00
- R32 gts-t plastic wheel trims – all of them $10.00
- R32 gts-t power steering reservoir and lines - $20.00
- R32 gts-t gear boot surround - $5.00
- 2 x R32 Front cross member supports - $20.00
- R32 coolant overflow bottle -$10.00
- R32 washer bottle - $10.00
- R32 rubber intake pipe with spring inside (stop sucking shut on boost) - $20.00
- R32 air conditioning grille and freezer - $30.00
- R32 alloy intake pipe with silicone - $20.00
- R32 turbo fuel pump - $30.00
- R32 fuel rail $10.00
- R32 air-conditioning line $10.00
- R32 HICAS rack – FREE
- Rb20 engine/computer loom (some wires missing) – FREE\
- RB 5 bolt stainless dump pipe (needs to be welded to exhaust) - $10.00
- R32 boot interior - $60.00
- R32 castor rods - $20.00 pair
- R32 gts-t rear bar drivers side marks - $20.00
- R32 GTR front bar missing lip, black - $50.00
VH41DE
- 1 x Automatic Gearbox of a 1993 Nissan Y32 Cima VH41DE Half Cut with 75,000k's in perfect condition – make excellent drag gearbox - $400.00
UNIVERSAL
- 1 x Jasma performance muffler, had on my r33, great note! - $70.00
- 1 x KnN pod filer - $10.00
- 1 x Blue Anodized Pod Filer - $10.00
- 1 x RaceTech Boost gauge - $10.00 (in cup)
- 1 x Pro Comp Oil Temp Gauge With sender unit $30.00
- 2 x rb water pumps - $5.00 each
- 2 x universal roof racks - $30.00
- Custom Billet 10mm hub centric wheel spacers - $40.00 4 x 114.3PCD
RIMS & TYRES
- 4 x r32 gtr rims (Rears: Toyo proxy 245's 80% heaps of tread and fronts tires need replacing) (5 x 114.3PCD) - $500ono
- 4 x r33 gts-t rims (little gutter rash, all straight tires need replacing, 5 x 114.3PCD) $150.00
- 4 x r32 gts-t rims (very little gutter rash, all center caps, tires need replacing, 5 x 114.3PCD) $200.00
- 4 x r34 gts-t rims (little gutter rash, tires need replacing, 5 x 114.3PCD) - $150.00
- 2 x ANZ 17" 5 x 114.3PCD, tires need replacing - $100.00
- 2 x Rodney Jane Racing Wheels, tires need replacing 5 x 114.3PCD - $100.00
- 2 x 300zx wheels, 5 x 114.3PCD, tires need replacing - $70.00
- 1 x s13/s14/r32gts/r33gts space saver (4 x 114.3PCD) - $20.00
- 1 x r33 gts-t rim, 60% tread - $30.00
Please do not hesitate to call/text on 0419761510 or email [email protected]
Edited by H@ME
https://www.sau.com.au/forums/topic/382186-nissan-parts/
anything other than the stuff you listed?
looking a plastic panel that protects the fuel filler neck int he drivers rear wheel area/
https://www.sau.com.au/forums/topic/382186-nissan-parts/#findComment-6114470
Hi mate I'd like to require
Do you also happend to have R32 Front seat belt buckles? thanks
https://www.sau.com.au/forums/topic/382186-nissan-parts/#findComment-6115353
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
