Selling my r32 as I just don't use it for what I intended on.. Bought it just over 2 yrs ago pretty much stock n has been my daily for almost that whole time.. Very clean example
Engine:
Rb20det 129000
Hks 2530 braided lines
Greddy cooler
80mm alloy radiator
Nistune
550cc seimen injectors
Greedy profec b 2 boost controller
Apexi intake pod in box
Yellow jacket coil packs
3inch turbo back exhaust/high flow cat.
Always used 98 octane fuel and high quality oil changed every 5000k..
Has..
Matte black lenso d1rs 18x10 +22 rear 18x8.5 +32 but has 20mm bolt on spacers front
Bc er series coilovers external resivoirs less than 3000k old
10 kg and 8kg springs
Gtr front bar
Carbon roof spoiler
Saber boost gauge
Nismo gear knob
Blitz turbo timer
Clarion DVD player
Pioneer speakers front n rear
15% window tint
Adjustable camber n castor rods in front
Opm deep dish wheel
Drivetrain:
Rb25det gearbox
Extreme 5 puk brass button clutch with carbonic inserts super bitey never slips!
Shimmed diff
Never been down the strip or tracked
Would of forgot stuff was just a rush ad on my phone I don't no how to add photos on here but I have heaps of photos on my phone I can send if interested txt 0431189311 located in Newcastle area
https://www.sau.com.au/forums/topic/382918-r32-gtst-222rwkw/
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
