i have a r33 gtst and while im accelerating with my foot to the floor, when i hit about 4 or 5 thousand rpm i get a massive pop comming through the exhaust. its not that loud but while it does the single pop the car stopped accelerating for that brief second and then screams the rest of the way to red line.
im worried if this is a bad thing or if it can do any damage at all.
any ideas?
https://www.sau.com.au/forums/topic/38298-popping-exhaust-while-accelerating/
Sounds like fuel cut from the boost limiter in the stock CPU.
If your not running more then 9 or 10 psi or do have a boost cut defender then it would be the fuel supply not keeping up with demand as you come on boost hard.
Another cause is old or faulty plugs, or wrong plug gap. Take em out and inspect the colour and condition of the core and electrode.
The reason why i would think it is not plugs initially, is the fact that it happens only at 5-6 grand and then cleans up to the red line.
When my plugs were bad it broke down all the way to the red line when ever under high boost load.
yes i mean that ...kind off like when its hitting fuel cut , u will see a blast of black smoke during that pop....
you will know if its pinging mate , just listen for a ratteling sound coming from the valve train ... like a clangy sound , that means its realy lean and its pre detoating due too great heat in the combustion chamber, if its doing this STOP! straight away or youll have melted pistons in no time ......
well if u can see no puff of smoke i think u might be leaning out mate ... how much boost are you running and do u have a fuel cut defender or anything else modified too your computer system
"Wont damage the car man just the DAM engine ... just imagine your seeing your girlfreind ***ing another bloke infront of you , thats how bad the engine is hurting when your leaning it out ....."
Um yeah......... You could put it that way I suppose. LOL
ummm ive actually knoticed my poppin..but its only when i like rev it to say 5-6000rpm in first gear and wen i knock it down to 2nd, it makes the pop noise..
is my problem the same as letemlaf ?
its mainly the rich fuel curve in the fuel map after boosting hard you back of str8 away and there will be excess fuel in the exhaust and combustion chamber and when u come back on hard you are just burning alot more fuel at that moment thats why u get a wicked pop and maby even a shoot of flame if u have a hi flow cat or better yet non at all ..
it sounds like your coil packs are getting tired, mine does the same thing. check plugs first - i'd put new plugs in people recommend gapping them to 0.8. if you've done that and it's still missing i'd say coil packs.
yes it would be this man but if it was popping and farting all the way up the load range not just at 5-6k ........ but yes check the GAP .8 of a mill is the way too go .....but i realy do recomend a fuel pressure check and fuel flow check ...
yeh any mechanic with the device , just say i think my fuel pump may be on its way out and need a check up for flow and pressure , would be better on a dyno , not much if its just a check without a dyno about 30 bucks but if u wanna check up on the dyno well im not sure there i say around 100 .... ? all depends on the leniency off the mechanic
im gonna take the spark plugs out and check them tomorrow morning,
at the back of the black cover theres some kind of sensor or something.
is that hard to take off and replace or is there anything else that might be a ittle bit tricky that i need to watch out for?
then ill get the fuel flow tested
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
