Hey, lately ive been looking around at all types of cars,
But.
seeing the prices's of N/A r34's are ridiculous.
15k-18k, really?
back in NZ you could pick one up for 9k in great condition.
and better yet pick up a tidy r32 GTR for the same price.
anyways thats my little hissy fit for the day haha.
would be good to see what people have to say about this.
https://www.sau.com.au/forums/topic/383234-overpricing-of-r34s/
I agree.
$15k - $18k?! Yes that is ridiculous!
Fucking bullshit, in fact :laugh:
I would not pay anymore then $9k considering it being in top condition or I'd pay around $7k - $8k.
And I love all the comments how they can justify selling it for prices from $15k - $18k.
yeah thats the thing that has me scratching my head.
im too worried about buying a turbo'd car
as most are less expensive than N/A's
i guess at the end of the day as long as its checked out all good,
theres no problem with a cheap deal?
i still think this is ridiculous haha.
cheers for the input
Are you interested in a NA R34 mate?
Mine is for sale. PM me for info.
No offence mate, but theres no reason for me to be interested in a N/A when i can drive turbo?
plus i would never pay that amount for a non turbo r34. thats why i posted this thread.
Just checking lol.
First of all; This is Australia, not New Zealand. You can't buy imports for f**k all here like over there.
And in Queensland (where i'm from, obviously) the current p-plate laws make N/A skylines more desirable then they ever were. Prior to july 2007, no one had a reason to import a non-turbo skyline, apart from if they wanted to be crap. With the new laws, it was all p-platers could drive. So there was less people wanting to purchase turbo cars (key demographic - 17-20 years old has been ruled out) and more wanting to purchase N/A skylines, which there were less of in the country.
Supply and demand. Non-turbo silvias and skylines are selling for as much now as they were in 2006 roughly.
At the end of the day, something it only worth what someone is willing to pay for it.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
