Need Help Finding/tapping Into Return Fuel Line
Hi guys
Planning to install my GM flex fuel sensor + zeitronix ethanol content display and need to tap into the return fuel lines under the bonnet
Does anyone have a pic showing exactly where this is, and if i need any kind of special tool to remove the oem harness/plug?
I'll be doing this with the help of my local mechanic on sat - im assuming ill need extra hose length too, can anyone recommend a particular brand that will hold up under the pressure, i dont want any leaks
edit - is this it?
Edited by domino_z
Nagtroc had pics up in a thread only last week i reckon - try search for thread on emptying the "gas" tank. <BR><BR>here ya go - <A href="http://www.nagtroc.org/forums/index.php?/topic/63088-how-to-siphon-gas/page__p__788634#entry788634">http://www.nagtroc.org/forums/index.php?/topic/63088-how-to-siphon-gas/page__p__788634#entry788634</A>
Edited by turboadam
Dom, it's the hose that connects to the BLUE connector in the pic (not the one the guy is holding)
You pinch the blue connector with your fingers and pull the hose up to disconnect (no special tools required) then the hose that comes off is where the fuel will come out. So either connect a hose to that (just buy some 15/20mm hose from hardware) and drain into jerry can. Just watch it when you pinch off the hose as a little fuel will splash out.
Also, be careful to make sure the blue clip doesn't come off the lower hose (it just sits there.. can easily come off and fall into engine bay).
actually on 2nd look the hose the guy is holding plugs into the blue connector, but obviously he's attached something to drain fuel away. Anyway, disconnect the hose connected to the blue/green clip, and should be good.
or are you running dual maps and just want to monitor the Ethanol content?
yep exactly that
i find myself using solely caltext e85 now - with the lack of carbon build up, smoother running and extra power, i cant go back to 98ron
i have bought 2 20L drums of e100 from racefuels so the plan is to top up a few L's of e100 if the local caltex brew dips in the low 70s or below
also having the flex sensor all setup does allow me to run flex fuel maps in the future - im sure cobb are already working on this as ecutek have been
Will be interesting to see if any of the 98 blends have a hint of ethanol in them....if you ever go back to 98 lol
Factory ECU's have come a long way, does the ECU support dual maps, or do you flash/upload a new map from the Cobb unit?
Oh that was nice of Nissan lol
I wonder if the Dealership mechanics do the "you're a dick head map" to people they don't like, like some Ford dealers were doing with the BA XR6T's and de-tuning cars that had a few dubious warranty claims
Not sure if they're working on an R35 one (or maybe already released), but Link sell a great ECU that adjusts the maps on the go based on inputs from the ethanol sensor. Dom call Yavuz on 0296312470 and he can explain if you like :)
im really happy with the cobb and the current willall tunes - i definitely dont want someone else tuning my car now that's it all sorted 100%
if cobb are working on a proper flex fuel system than i'll just wait for that
Edited by domino_z
    • Yeah pretty impressive hey, good to see quality products not over-shooting their prices. That's what drew me to buy the hypergear turbo, just a shame I've never got the chance to see it in action
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
