I have some gtr parts left over from my r32 I bought and the car was full of rust and had everything transferred over into new shell what is in the pics is what's for sale.
Pair of front indicators no scratches although each has mount broken where it pushes onto headlight.
Passenger side seat
R32 gtr grill X 2 $75 each
Rb26 vavle covers and valley cover paint bayside blue $100
Rb26 standard fuel rail $10
R26 mines pod adaptors running z32 afm's with blitz filters i think $200
R32 gtr ecu has mines sticker on it and nistune written on it. Was running my 888cc siemens injectors and 25psi $200
R32 gtr front pods side skirts and rear pods. $100
R32 Rb26 standard plenum in black hpc coating $170
R32 gtr dash board slight lifting. $150
R32 gtr lower steering column cover $30
R32 gtr door arch strips and rubbers $40 each side
R32 gtr Front gaurds on dints pass has bubbles on lower half but no rust on inner side. $150 each
R32 gtr doors less switches $120 each
R32 gtr boot interior lining rear over boot latch $30
R32 gtr boot lining pass side $30
R32 gtr front windscreen gutter tray no cracks $50
R32 gtr stock intercooled $100
R32 gtr stock radiator $100
R32 gtr centre console $80
R32 gtr gear surround plastic with 2 screw holes on pass side with no boot $50
R32 gloove box $60
R32 gtr driverside kick panel $20
R32 gtr plastic sill covers $30 each
R32 gtr interior light $20
Ame wheels to suit gtr with 215/45/17 tyres that are 80% tread $600
Pick up is available from greenbank. Phone number is 0424607516 Thanks
Uploaded with ImageShack.us
https://www.sau.com.au/forums/topic/383661-fs-r32-gtr-parts/
  • Replies 50
List updated
Front indicators mount broken where clips onto headlight $50 each
Passenger side seat $100
R26 mines pod adaptors, afm's with blitz filters i think $200
R32 gtr dash board slight lifting. $120
R32 gloove box $60
R32 gtr front calipers $50 each
Ame wheels to suit r32 gtr $400
Tein coilovers type nr to suit r32 gtr $500
Pics as request of afm's mine's adapters and pod filters. $200 for everything.
Also have a standard speedo with white faces inserted not sure what brand has a c on it $200
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
