Hey Guys,
Its time for me to part with my wheels... They are a 15x8 -72 offset is 4x114.3 and 4x100.
They are in reasonable condition. Chrome is starting to age in places and could do with being refinished!! The wheels also come with Bridgestone Potenza G3 205 55 R15 tyres with 90% tread (one tyre has a few chunks out of the sidewall). Chances for wheels in this spec dont come round often so get on it quick. $650 ono
Edited by benny240z
Sort of want.. Where are you located?
Located in Frankston South, Victoria can package and deliver to dandenong E-GO Depot!!
Edited by benny240z
Come with centrecaps?
Are these 1piece or split design?
Chance of more pics..
Wider shot perhaps & backsides..?
Edited by krayzie32
Hey Mate,
No centercaps (was planning on painting the centers black)
They are a 2 piece with the centers welded into the main hoop
Here are some more pictures.
Edited by benny240z
