  • Replies 5.5k
Posted Images
Having enjoyed two days of testing in Valencia, former World Champion Kimi Raikkonen is feeling "very positive' about his return to Formula One.
The Finn spent Monday and Tuesday driving a 2010 Renault R30 at the Circuito Ricardo Tormo in a private testing session. The Lotus driver got 171 laps under his belt as he reacquaints himself
with an F1 car after two years on the sidelines.
"It went well today and overall the two days have been helped me a lot," said the 32-year-old.
"Having not driven a Formula One car for two years and obviously with a new team, there is a lot to get used to. I'm happy because I was pretty quick to get back in the groove."
"Even though I was using a two year-old car and the Pirelli demonstration tyres, I learnt about working with the team and the engineers which means I can focus on the new car once we get to Jerez for the first official test.
"It was great to be driving an F1 car again and from that respect I feel very positive."
Having admitted after Monday's running that he was highly impressed by Raikkonen, Lotus' trackside operations engineer Alan Permane was pleased with how the 2007 World Champ upped his game on day two.
"We enjoyed another good day with Kimi in Valencia," he said.
"The morning was spent doing set-up work in particular with front and rear cambers. In the afternoon we ran very low fuel qualifying simulations with two new sets of tyres followed by a 27 lap run starting with a full tank of fuel.
"Kimi's pace improved from yesterday as we would expect and we completed several start, pitstop and clutch simulations. We were even able to finish early as we completed our programme ahead of time.
Overall it has been a productive and valuable two days."
http://www.planetf1....-Test-A-Success
Edited by tweety bird
"Sadly, it doesn't make the FF look any better"
oh the lulz
what a pig ugly panamera look-a-like
oh the lulz
Oh you'd better believe I laughed at that comment too!
They have a quickly growing McLaren section too.
Nothing beats the photo threads though, easily the best available
... oh sweet jesus what have caterham done
we can only pray to allah that this doesnt work as a concept, the last thing these cars need is to look even uglier
that hump up the nose will produce a small amount of pressure at the point of the front suspension, but can't see it making that much of a difference!
hmm maybe time to make one up and run some simulations :whistling:
ruben's going to race in circles.
According to The Associated Press, anonymous sources have revealed that the 39-year-old will be behind the wheel of the new Dallara DW12 chassis at the Sebring International Raceway for two days next week.
http://www.planetf1.com/driver/18227/7456663/Rubens-to-break-promise-with-Indy-test
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
