  • Replies 5.5k
Posted Images
We didn't know he could be so funny... At the Australian Grand Prix Kimi Raikkonen showed that he's not the Iceman and in fact a lot more like veteran whinger Victor Meldrew. In the middle of the race he got on team radio and yelled angrily, "Why do I get all the blue flags?" To which his engineer replied: "the blue flags are for the cars behind, Kimi".
So, just in case Kimi is feeling a bit rusty about the flags he might see out on the track - none of which he's taken much notice of over the years - here's a refresher.
Blue Flag
Meaning: You are about to go a lap down, NOT, you are about to go down on a Lap (or in a lap-dancing club)
Yellow Flag
Meaning: Think about slowing down.
Double Waved Yellow Flags
Meaning: Oh, don't bother, it's probably a lot of fuss over nothing i.e. like when Takuma Sato blew engine smoke all over the exit of Eau Rouge and you went steaming through at top speed.
Orange Flag
Meaning: There's oil or debris on track, or as Takuma once said, "very slippery oily stuffs"
Green Flag
Meaning: You must drive in an eco-friendly manner from this point on.
Red Flag
Meaning: Vitaly's gone off somewhere again.
Red Light at End of Pitlane
Meaning: In about five seconds time Lewis is going to smash into the back of you.
Black Flag
Meaning: Race Control has been taken over by pirates. (Normally with a number showing how many pirates)
http://www.planetf1.com/features/7614078/Kimi-s-Quick-Guide-To-F1-Flags
As was the case in 2011, there will only be one DRS zone in place at the Sepang International Circuit for this weekend's Malaysian GP.
The detection point for the zone begins just over 200 meters before the final hairpin with the activation point as the corner is completed. As a result, drivers will be able to make use of DRS for the entire pit straight.
In total, 18 overtaking maneuvers were completed using DRS at last year's race.
http://www.planetf1.com/driver/18227/7615725/One-DRS-zone-in-Malaysia
If you are heading to Sepang for this weekend's Malaysian GP, pack your umbrella as thunderstorms are forecast.
As the rain came down in the Sepang paddock on Thursday afternoon, it was perhaps a sign of things to come for the rest of the weekend.
Although the teams and drivers can expect hot conditions, with the high hovering around the 30'C mark, they can also expect rain.
According to the meteorologists, thunderstorms have been forecast for all three days and are expected late in the afternoon.
So expect a wet one...
http://www.planetf1.com/driver/18227/7616592/Wet-weekend-expected-in-Malaysia
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
