p3 times.
Pos Driver Team Time Laps
1. Lewis Hamilton McLaren-Mercedes 1m35.940s 13
2. Jenson Button McLaren-Mercedes 1m36.093s + 0.123 12
3. Nico Rosberg Mercedes 1m36.389s + 0.449 16
4. Michael Schumacher Mercedes 1m36.512s + 0.572 17
5. Mark Webber Red Bull-Renault 1m36.635s + 0.695 16
6. Pastor Maldonado Williams-Renault 1m36.765s + 0.825 17
7. Sergio Perez Sauber-Ferrari 1m36.781s + 0.841 19
8. Kamui Kobayashi Sauber-Ferrari 1m36.880s + 0.940 17
9. Sebastian Vettel Red Bull-Renault 1m37.039s + 1.099 15
10. Kimi Raikkonen Lotus-Renault 1m37.061s + 1.121 17
11. Nico Hulkenberg Force India-Mercedes 1m37.237s + 1.297 16
12. Romain Grosjean Lotus-Renault 1m37.274s + 1.334 19
13. Paul di Resta Force India-Mercedes 1m37.288s + 1.348 16
14. Bruno Senna Williams-Renault 1m37.425s + 1.485 14
15. Fernando Alonso Ferrari 1m37.465s + 1.525 12
16. Jean-Eric Vergne Toro Rosso-Ferrari 1m37.493s + 1.553 13
17. Daniel Ricciardo Toro Rosso-Ferrari 1m37.628s + 1.688 14
18. Felipe Massa Ferrari 1m37.831s + 1.891 14
19. Vitaly Petrov Caterham-Renault 1m38.701s + 2.761 19
20. Heikki Kovalainen Caterham-Renault 1m39.198s + 3.258 19
21. Timo Glock Marussia-Cosworth 1m39.796s + 3.856 18
22. Charles Pic Marussia-Cosworth 1m40.048s + 4.108 17
23. Narain Karthikeyan HRT-Cosworth 1m41.263s + 5.323 14
24. Pedro de la Rosa HRT-Cosworth 1m41.499s + 5.559 18
vettel and kovalainen where the only two on medium tyres. :thumbsup:
http://www.autosport...rt.php/id/98799
better mc boy?
  • Replies 5.5k
Posted Images
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
