p2 Times
01 Sebastian Vettel Red Bull 1:37.718 17 laps
02 Mark Webber Red Bull 1:38.475 0.757 36 laps
03 Fernando Alonso Ferrari 1:38.483 0.765 35 laps
04 Lewis Hamilton McLaren 1:38.748 1.030 31 laps
05 Jenson Button McLaren 1:38.786 1.068 32 laps
06 Felipe Massa Ferrari 1:39.029 1.311 33 laps
07 Nico Rosberg Mercedes 1:39.448 1.730 32 laps
08 Bruno Senna Williams 1:39.531 1.813 38 laps
09 Kamui Kobayashi Sauber 1:39.653 1.935 36 laps
10 Michael Schumacher Mercedes 1:40.115 2.397 30 laps
11 Kimi Raikkonen Lotus 1:40.166 2.448 32 laps
12 Pastor Maldonado Williams 1:40.230 2.512 35 laps
13 Romain Grosjean Lotus 1:40.286 2.568 32 laps
14 Sergio Perez Sauber 1:40.326 2.608 35 laps
15 Daniel Ricciardo Toro Rosso 1:40.435 2.717 30 laps
16 Jean-Eric Vergne Toro Rosso 1:40.516 2.798 32 laps
17 Nico Hulkenberg Force India 1:40.700 2.982 34 laps
18 Paul di Resta Force India 1:41.430 3.712 35 laps
19 Heikki Kovalainen Caterham 1:42.476 4.758 38 laps
20 Timo Glock Marussia 1:42.652 4.934 33 laps
21 Vitaly Petrov Caterham 1:42.846 5.128 38 laps
22 Charles Pic Marussia 1:43.538 5.820 38 laps
23 Pedro de la Rosa HRT 1:44.453 6.735 16 laps
24 Narain Karthikeyan HRT 1:45.114 7.396 20 laps
http://www.planetf1.com/driver/3213/8253198/Prac-Two-Two-from-two-for-Vettel
  • Replies 5.5k
Posted Images
the old aero packages generated too much downforce, and the FIA periodically has to fiddle with the allowable wing dimensions to keep cornering speeds reasonable
*waits for some retard to say driver and spectator deaths are a perfectly acceptable trade off for 'spectacle'*
yer coz tyres that delaminate is so much more ''safer''................. :rolleyes:
Having tyres that delaminate is safer than having higher speeds. One is only a drama at the end of the tyres life, the other means that if something goes wrong at a higher speed, there is more chance of injury or death.
Ferrari pushing the rules to the limit and deliberately getting Massa a grid penalty to move Alonso up another spot. Clever, but if it was Red Bull doing that everyone would be spitting chips calling them cheats
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
