Hey all,
I've had this car for about a year and purchased it completely standard from a guy up north. It has been meticulously maintained, serviced every 5000km with Royal Purple 10w/40 and daily driven. For the last 6 months or so it has been primarily driven by my girlfriend (even so, car has always been warmed up before driving) as I've gotten my motorbike license and have since been riding everywhere :P. Reason for sale is that I don’t need 3 cars, I have this, a track R33 and a bike - since I daily the bike this really is no longer needed and would just sit around (my girlfriend now has a car of her own).
Modifications are minimal, just the essentials really - as follows.
Splitfire Coil packs
Tein S-Tech springs to bring it down to a reasonable height.
GIZZMO Electronic boost controller set at 10PSI (never ran higher)
Nistune Reprogrammable ECU tuned by GT Garage (to suit the boost change, otherwise the Neo's tend to over fuel) with a dyno sheet for ~175RWkW
EBC Greenstuff Front and Rear Brake Pads
EBC Ultimate slotted and cross-dimpled Front and Rear Rotors
Apexi Turbo Timer
Alarm/Immobiliser/Central locking
Stock Airbox with Apexi drytype high-flow panel filter
Stock Exhaust (and the limitation for power, a 3" system would bring it up to around 190kW which is a more reasonable figure, I just liked quiet for daily)
Alpine MP3 CD player head unit
Body & paint are in great condition!
Asking $16,300 - Located in Hobart, Tasmania
Edited by SKiT_R31
https://www.sau.com.au/forums/topic/384590-nissan-skyline-r34-gt-t-sedan/
  • 1 month later...
  • 1 month later...
  • 2 months later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
