For sale is my pride and joy midnight purple 1995 r33 gtr!
This car was setup tp be as stealthy as possible while still having some decent power
This car owes me over 45,000$
Body
Midnight purple respray , immaculate!! has been resprayed with a touch more gloss looks stunning was originally the same colour just was keyyed so got the full spray job!
18inch volk gtc rims in gold , on this car these wheels look great 285 all round with 80% tread , looks tough with the fat wheels
tein adjustable coilovers set to legal limit to keep the police happy
series 3 front lip
exterior of this car is neat and tidy no overkill just the standard good looks of the gtr!
Interior ,
interior is standard no gauges ect , all electronics are hidden away , nismo 320km dash
engine , i bought the car and spun bottom end bearings so over 10 thousand was spent on the rebuild!
rb26 block acid dipped , bored out 0.40 , balanced ect
crank bearings oversized
Arias forged pistons
shot peened and heat treated rods
arp rod bolts
whole bottom end remachined crank rods ect!
nitto high flow oil pump
tomei oil restrictors
tomei sump trap doors
arp headstud kit
cosworth 1.5mm drag series head gasket
n1 water pump
nismo thermostat
oil sandwich plate and filter relocation
engine covers sprayed midnight purple
everything was done to reduce risk of another bottom end failure have full receipts for the build
turbos/intake
trust t517z 10cm turbos x 2
match ported manifolds with brand new gaskets
hks dump pipes
twin 3inch y pipe into single 3.5inch exhaust very high flow , bought the exhaust from Boostdr was on his car before he upgraded not too loud for the street
standard twin turbo pipe/intercooler for stealth under bonnet look
apexi twin hardpipe intake apexi pods
z32 afm's
electronics/fuel
1000cc injectors with impedance pack removed
turbosmart fpr stashed away
single 040 intank
apexi power fc / hand controller
blitz ebc
transmission
Auto gallery yokohama 1-5 close ratio gearset
super hd 1-5th gears with double cone syncro's
os giken input and mainshafts
hd selector fork
redline shockproof
valued at 12,000$ aud for the set not installed!
+ previous owner recently had 5th gear rebuild in one piece billet from award gearbox sydney , can contact previous owner for receipts
NPC billet clutch and lightened flywheel rated at 700hp
vspec active lsd diff
power 375kw@wheels - 20psi which is tuned on a very rich 10-1 afr , could lean out + more boost for over 400kw at wheels , ive just left it safe as it is quick enough!
the bad , turbo seal on front turbo is on the way out as it has slight oil out the exhaust when cold , i will pay for both turbos to be completely overhaulled and supply receipts if the asking price is met! if not take it for less as is!
5th gear is a little bit harder to get in than a standard set as it has been rebuild one piece billet , i am used to it and get it in no worries but im fussy
the exhaust is way to large on the twin 3 inch area and at times taps against the body could be spaced a bit more by an exhaust shop if it bothers you
everything else has been sorted as i mentioned i have spent 15,000+ on drivetrain of this car making it a stealth street weapon! , the time unfortunately has come that i need a reliable daily to get me to work and need to pay of my loan!!
will sell for 35,000 with reconditioned turbos , fresh service and one year rego + custom plates
or 32.500 turbo seals as is , is very powerfull and driveable as is , have been driving this way for 2-3 months just wheteher your fussy or not!
would consider partial trade for ""reliable"" daily + atleast 15k my way
0434008133 or pm , ive probably forgotten something so for any more info or pictures pm cheers
chassis has done 100,500 kms
engine has done 3,000km since rebuild with 1,000 of them being break in km!!
have only done 6,000 km in over a year of owning the car weekend car only , always warmed up / cooled down, washed and loved!!!
  • 3 weeks later...
alright bit of an update.. turbos turned out to be fine with the normal left to right shaft play that t517's have , go thte tune looked at and mechanic found it was sitting at 9-1 air fuel ratio!!! which is stuped rich and had 2 split intercooler hoses ,, needles to say i am never going back to my original tuner!!!
bought a set of splitfire coilpacks and had the car compression tested a solid between 128 - 132 across all 6 , this low comp is due to a 1.6mm headgasket so good for high boost 25psi+!!
since the retune and oil change no smoke is noticeable at deccell or idle , just the usual blackky fuel puff at full throttle and high boost,,
car has a little bit of trouble starting once hot but with a bit of throttle she kicks over , its a bit of an intermittend fault that i cant find atm!!
paint and interior is immaculate would be hard to find one in this condition!!!
genuine 350+mainline kw at 20psi or 375kw dyno dynamics!!
cams were also dialled in boost now coming all in by 5,000 and starting just after 4,000 not bad for a rb26 with thick h/gasket!!
Man i remember this thing when it was first imported, thru erwins shop! was a sick car then and sounds like its a better car now, wish i had the coin sad.gif
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
