Hey guys selling my DEFI copies and my mate is selling his Apexi copies.
DEFI BF Series Style gauges consist of:
OIL TEMP
OIL PRESSURE
BOOST
AIR/FUEL RATIO
They all come with sensors/wiring/visors/mounting plates/instructions etc etc.
APEXI EL System Meter Series Style gauges consist of:
WATER TEMP
OIL TEMP
OIL PRESSURE
BOOST
AIR/FUEL RATIO
They come with all sensors/wiring/mounting plates etc etc.
Pictures up in an hour.
After $200 firm for the DEFI's
After $270 firm for the APEXI's
All brand new sealed yadda yadda
Located 15 mins from PARRAMATTA SYDNEY NSW (not cabramatta lol)
Can post one set of gauges for $25 EXPRESSED anywhere in Australia with tracking number.
For now:
APEXI's look like this (right one)
DEFI's look like this when white:
And look like this when red:
Edited by cabramatta
https://www.sau.com.au/forums/topic/384954-apexi-defi-style-gauges/
