Hey guys,
Selling my splitfire coilpacks as title says..
Comes in the original box.
They r still in the car atm but selling the engine and dnt have a cooler so its nt runnin..
Happy to wrk something out if ur looking at buying engine too..
Im after $390 for them
Happy to ship at buyers expense..
Located in Mordialloc
Please msg me if you have any questions.. 0432647023
Cheers
Herb
https://www.sau.com.au/forums/topic/385088-r34-gtt-splitfire-coilpacks/
Sorry to add on but I also have a full set of Spitfires I removed out of my Stagea this week. Car was going into limp home mode & thought the coil packs could be factory, I purchased a new set of red ones from ebay only to find Blue Spitfires already installed. I swapped them out for the red ones & still limping home :P
I couldn't be stuffed removing the red ones so the full set of Blue Spitfires are for sale. My engine is a Series 1 RB25DET (not NEO), no external igniter.
Thanks.
ps, sorry GTXR34, if any problem, I'll move to new thread.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
