Bit of a clear out of parts I no longer need, reasonable offers considered. I will add more as I remember.
1. Bosch 044
Limited use, two available. Was going to run twin pumps but going with a large single instead.
100each
2. HKS DB Chrono Boost and Oil Pressure Gauges
Include all cables, control unit and sensors. Pricey buggers no longer in production. Very slim profile (can easily be double sided taped anywhere on the dash). Have peak recall, replay and all that jazz refer here for full description:
http://www.nengun.com/hks/db-meter-chrono
300 for the pair
3. Surge Tank
Includes 6AN hose tail fittings. Bottom outlet is -10AN.
120ono
4. Optima Yellow Top Battery
Limited use. Presents as new. Terminals included.
330ono
5. RB26 Long Motor
Standard rb26 head
Arias forged pistons, N1 oil pump
Std bearings etc
Completely rebuilt ~10k km's ago, leakdown was in the 18-22% range when last checked. This motor didn't have any piston slap when cold but did use a reasonable amount of oil (built with generous tolerance's by previous owner).
Ideally suit rebuild/freshen up.
Does NOT include cam covers, sump, plenum, balancer or any ancillaries.
1500
6. TIAL 50mm BOV
Black, un-marked. As new
200ono
7. WEDS TC005 17 x 9.5 +30 forged
Ultra-light (7.3'ish kg per corner) wheel with concave face. Easily clear 355mm brakes as pictured.
1750
8. Greddy Oil Cap
Blue.
100ono
Will post anywhere in Aus, buyer pays shipping.
PM or email [email protected]
https://www.sau.com.au/forums/topic/385541-fs-weds-tc005-17-x-95-30-forged/
044 internal or external and 50mm bov plumb back or not?
BOV isn't plumb back.
As the guys above said, 044 can be run in tank or external but these two are spoken for.
No probs Rob.
Had a few queries on cost to ship the wheels, freight to most area's is ~120 using TNT road. Obviously a lot more if you live in the middle of no where!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
