Sorry for sounding stupid but I know very little about turbo sizing and what all the numbers mean.
I have in my possession a turbo that I was told is from an RB25 but noone knows for sure.
There is very little on it to say what it is so I hope someone on here can help me to decipher it.
The compressor housing has 45V2 on it and nothing else apart from "nissan".
The exhaust housing has 21U and 928A on it.
There are no AR numbers or anything.
Does this mean anything to anyone?
https://www.sau.com.au/forums/topic/38565-what-turbo-is-this/
Boost pressure has nothing to do with it - it's all about shaft speed.
If you increase the VE of the engine (ie a set of cams, or new inlet manifold, or exhaust system) you will find that the turbo will now fail at, say, 11 or 12 psi, as higher engine VE = more compressure RPM for the same boost.
:O
Cheers,
Matt
Well, technically boost pressure *does* have something to do with it, because on the stock turbo, at a given psi, you'd know that the shaft is spinning at X rpm... so we know that at around 13-14psi, the shaft on a stock r33 turbo would be doing the magic 'breakpoint' of X rpm, and would break itself into teeny bits and pieces.
I'm not following your example... feel free to enlighten me on what 'VE' is... but anyway... I disagree with it. :O
When the shaft is doing X rpm, it will fall apart, and you can use the fact that the *stock* impeller, will be pushing X PSI at that point. Even if it was spinning up faster or slower, that won't effect the shaft speed at which it'll break. Changing your cams or a manifold or exhaust system won't change the fact that the turbo will break at roughly X rpm, and thusly, will break when the stock impeller is generating 14+psi. Those mods won't change the spool profile of the stock turbo.
Edit: I've actually walked away and thought of something. I apologise, you're dead right: with a bigger intake manifold, tehre's more space for the turbo to fill up, therefore the turbo will be at Breakpoint rpm, but not reached the magic 14psi. Therefore, it will break at a lower psi. However, if the intake/manifold is stock, and the exhaust is changed, or the cams have changed, it won't break at an earlier psi, it'll just reach that psi faster.
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
