i have 18x10+20 with 285 tyres on my gtr (te37sl)i have them for sale if u check my thread there are pics on it to see the fitment(not trying to sell them to you)i have rolled the front only but i do have 2deg camber on front the rear guards have been flared
hope this helps you
can u tell me where youi got the wheel spacers from?
thanks in advance
Edited by sycorb
Standard breaks its just there a flat face rim...i have no idea how to put pics up so here a link=) http://www.nlmotoring.com/XXR-521-Wheels-18x10-Flat-Black-p/52180142.htm
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
