  • Replies 58
QUOTE=strutto]Sedans...
Not 4 doors...
:P
I always call it a 4 Door....that way I can be reasonably sure that the average "ordinary Skyline" drivers can work out what the difference is :wassup:
only pic I've got handy at the moment
http://members.optushome.com.au/jay51/Black%20M%20Bar2%20(1).jpg
https://www.sau.com.au/forums/topic/38630-4-door-owners/#findComment-782697
Work in Belmont live down Rockingham way.
Don't know exactly how many Impul's were built but I think it was more than 100.
How much did I pay hey.....hmmmm Let's just say I don't think the dealer I bought it from knew (and neither did I when I bought it) how rare they are over here. From what I know Matt and I are the only 2 R33R's on SAU
https://www.sau.com.au/forums/topic/38630-4-door-owners/#findComment-783989
I have a R32 GTS-T Sedan
Pics
http://board.performanceforums.com/forums/...2125#post772125
Outside:
GTR front end including bonnet
R32 GTR wheels and brakes with lots of rubber, with callipers painted black and gold
Lowered 1.5 inches
Dark tinting
Inside
GTR dash and display i.e gauges are GTR set up with NISMO 260km/h speedo
Pioneer head deck, with Alpine speakers
Engine
Full 3inch exhaust
Upgrade R33 turbo
GTR fuel pump
FMIC
Boost controller
GTR inlet manifold (This was a bitch of a job!!, but well worth it)
Running 1 bar, but could run a lot more with better turbo
https://www.sau.com.au/forums/topic/38630-4-door-owners/#findComment-784243
4 doors = GTS-t with extra practicality! plus you always get a wave from other 4dr drivers
all the 'lines i test drove were 4 doors. come to think about it, i've never been in a 2 door skyline!
very tidy spooks :)
mine's fairly std with an R34GTT rear wing & turbo, apexi filter & a 3inch turbo back exhaust. oh & some fugly r33 rims
https://www.sau.com.au/forums/topic/38630-4-door-owners/#findComment-784386
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
