If you go on performanceforums and PM Babalouie he has ground up restored his Hakosuka, and may know where to find these parts.
Here are some off a 240k
http://www.ebay.com.au/itm/NEW-REAR-WHEEL-CYLS-FITS-NISSAN-240K-1973-1976-/330649680350?pt=AU_Car_Parts_Accessories&hash=item4cfc41b9de
https://www.sau.com.au/forums/topic/386316-hakosuka/#findComment-6161927
http://www.ebay.com....=item4cfc41b9de
thanks bro i got a part number off that link cheers
https://www.sau.com.au/forums/topic/386316-hakosuka/#findComment-6162374
Hey Danny - A bit late i know, and you probably already have it sorted by now? How did you go with the 240K one?
Here is a copy of the relevant pages from the parts book for both KGC10 and KGC110 for your reference :
K(P)GC10 Parts Book (1971):
K(P)GC110 Parts Book (1975):
Edited by prince_skyline
https://www.sau.com.au/forums/topic/386316-hakosuka/#findComment-6169544
