righto guys, problem.. help is needed.
we just had a major storm over here, fork lightning, strong winds. the works.
I noticed the storm was comming, so i shut down both the gaming PC and the server, turned off the battery backup system. and unpluged everything from the wall sockets.
after the storm had passed, plugged everything back in, server starts up fine. gaming PC loops itself.
turn on -> motherboard check -> loop -> loop -> restart.
i can not see the motherbaord screen ( i.e GIGABYTE welcome screen). so i am guessing either the power supply has somehow shit itself.. or the motherboard has finally packed it in. any help would be appreciated
intel core 2 quad Q6600 2.66GHz
GIGABYTE GA-EP45 - UD3L
Quadleadtek GTX 470
1 x WD green 1TB HDD ( boot drive)
seagate 1.5TB HDD ( secondary/storage)
Thermaltake Qfan toughpower 850W PSU
Kingston HyperX DDR2 RAM ( speed unknown. cant remember)
ah usual with tradition. something screws up over xmas period. (last yer the great HDD failure of 2010)
https://www.sau.com.au/forums/topic/386482-motherboard-failure/
explain loop - as this will help
i assume by motherboard check, it's posting then restarts
try pulling everything out except power and see if you get a post fail - no ram - if so mobo should be good - then start putting everything back 1 at a time - starting with ram - see if it post and stays on - then GPU - then HDD - then anything else
if it doesnt post or fail post it could be either mobo or PSU
just replaced the PSU with a backup i have ( 700W). and no change.
the loop is bascially restarting itself, i should of been more clearer. i cant get into the bios or boot menu because i cant get to the motherboard screen to press F12 / F9 to get bios/boot menu.
i'll try your suggestions tomorrow morning when i wake up :) thanks for the quick reply
Edited by liger
If pulling things out one by one does not work then do this:
Take out the battery on the mobo, flush (press power etc), and reinstall & try again with just CPU, RAM and a HDD/SSD. No GPU or other PCI items.
yeah i didnt think to clear the CMOS. so i'll get stuck into it early tomorrow morning.
another motherboard is on order aswell as some new ram ( to suit DDR3 mobo). if i fix it before they arrive, i'll keep them as spares.
Edited by liger
reset CMOS and tried to boot with 1 stick of RAM. the motherboard went past its self-test phase ( phase 1,2,3 LED's turned themselves off, before they would stay on).
so hooked up a HDD and GPU and i can now boot to windows. NFI what the problem was with it last night. probably that time of the month i imagine.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
