Hey Guys,may be one down :( My poor other half had a bit of a misshap is the "Stag" today, took out the rhr suspension and clipped the rhf rim and tyre after she spun it coming through a roundabout in Montrose. She wasnt the only poor victim either ( she came out lightly ), as when i arrived at the scene a girl in a Commo ute did exactly the same thing, except she collected the guard rail after spinning out into the kerb. According to the towie who picked us up diesel had been spilt from seville all the way into Montrose :verymad: . Add to this the massive downpoor of rain, the crappy "Chinese" tyres that were fitted for roadworthy by the seller,and the fact shes only just got this car, i guess it could have happened to anyone. Hopefully it gets fixed in time before the cruise. :rolleyes: We were both looking forward to this.
  • Replies 44
After so many months of waiting for my stag, i have finally got it. And it would be awesome to hang out with fellow stag owners. So i'll be there!!
Sunkist... it wouldnt be a cruise if you're not there.
Prince...definitely bring out a prince they are THE Nissan to have!
dennis are you going to do a proper thread....What time do think we should to get to yarra dam for BBQ..And where are we going to meet up with you guys..It is roughly 1.5 hours from the monash uni car park first meet point .i would say 10.30 for 11.00 departure for the drive..As sunkist said might be worth inviting the v35 skyline crew as well help with a few numbers...
Might be back in Melbourne for this one....If I am I'll be in
It will be funny for me....out in the westside (well north-west to be exact)...aint too many Stagea drivers around (to my knowledge..)
So it will be nice to be with fellow Stagea drivers....
is there going to be a meeting point for western suburb ppl? if so i'm in for sure!!!
(long lonely drive to monsh.... LOL)
if you want to put one up for the western subs GO FOR IT just make sure you put it in both threads as im not sure which one everyone is reading
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
