  • Replies 42
It means it was, from factory, a Non Turbo car.
Now that means the person you bought it from, who told you it was an "EX-Turbo" had gone and turbo'ed a non turbo car, then removed it all and sold it as stock non turbo again.
This isn't as bad as a Turbo car that had been neutered of its turbo and running low compression.
You do not have a 25GT-V but you do have a 25GT. Still, that's good news for you. thumbsup.gif
More likely it means the seller didn't know what they were talking about. Probably thought that all Skylines are turbocharged so this one must have been deturboed.
That's what I'm thinking too. But then again, some the habibs and morons out there would be stupid enough to go to the trouble of turboing an NA and unturboing it.. lol..
I'm thinking the same as you though Hanaldo. It's probably just a factory non turbo stock as a rock. They hype it up to people who know nothing about cars by slipping that magical word in. 'turbo'
Very nice, & welcome !
Love the Nismo front bar - looks very very nice with the wheels, in blue.
If you get sick of the wheels one day down the track simply powdercoat them white, would look even better IMO & is pretty cheap to do.
R34 Nismo-kit side skirts arnt expensive, if you can find them, & would finish off the 'looks' very nicely.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
