Hey Guys
Im after more then one Rb26dett Trust Sump extension
Any idea where to get from? More interested here in Aust or i guess Int will do if there no other options
Or if you have one for sale just pm meeee :)
Located in Syd
Regards,
Edited by thegame-01
https://www.sau.com.au/forums/topic/386709-rb26dett-trust-sump-extension/
Hi mate, i would suggest talking to brad at pro fab race engineering. i think his name is RISKING on these forums, he does some insanely neat work with aluminium and does some great dry sump setups. Im sure if you talk to him he can make you an extended sump, and i bet you wont be dissapointed :)
Cheers mate will look into it
There will be a genuine TRUST extension, welded by Hypertune to an RB26 sump coming on the market very soon in the parts section. Location Sydney.
If you must have a trust extension I have two customers who are having them removed from engines early this year. One is selling due to a dry sump conversion the other is going larger capacity. I believe both of them will be for sale.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
