ok. i tried searchin...wasn't on the first two pages,
realli can't b ***t to search more, not in the mood.
Anyways. This is wot happened.
Last nite, was givin the car a good hit, a couple of good hits. Never noticed a thing wrong, until i got told there was heaps of smoke comin outta exhaust(even at idel).
Popped bonnet and there had been a huge oil surge, or blow-by woteva u call it.
like there was blow by-before, but not this much...idel was perfect and the big clouds of smoke disappears after a while, the car ran fine, all two hours to home.
hehe lucky it didn't stuff up where i was...
but anyways, so today i drove a different car to by a oil catch can, got home took out all the pipes on the inlet side, the afm, the intercooler, and decreased them all. washed n put back on. Installed the oil catch can. then decided to take it for a drive.
1st gear, boost comes on, big short whooshy whistle sound from my left side engine bay, (it wasn't my blow off value)...have no fu kin idea wot that was.
then the car struggled, boost wouldn't come on. In fact, whenever its about to make boost, seems like its being cut off or something and evenutally want to stall. the more acelerator u press the more it dies.
pushed it back home. Big clouds of black smoke again, and big smell of petrol.
scrathin head for like 20mins. all i kno its runing rich like hell and the vacumm reading is like not normal. alot more close to 0.
-unplugged AFM, and it begins to die down. so can't b dat faulty.
-changed spark plugs, still idels n blows smoke like that
-when u rev it, the blow off won't work anymore.....just the farttin sounds from air filter like as there is no after market blow off, and the return pipe is blocked.
-i had a service two days ago.
thats all i kno...
Could it be becos the oil blow by last nite, was too much n went all thru the engine? Plz dun tell me its real ***t like pistons or rings n sh!t...but if u must, how much are these things to fix?
The car start fine, revs fine, just heaps of smoke, runnin really rich, (new set of spark plugs i put in are stuffed afready)
any ideas?? plz? plz?
Thankz!!!
https://www.sau.com.au/forums/topic/38673-carz-t-plz-help/
hmmm maybe mobile mechanic ay?>?
can;t drive it anywhere!
Oh...yea...
well does anybody kno if there might be a real easy solution to it??
like maybe a sensor is fckt or sumthing?? like apart from AFM.
this sux man. cos its onli last night going home i fifgured out how to launch on bald tires. :)
PualR33.......
u said check piping.......?? Wot do u mean? like if they are connected properly n not leaking? do u kno what that big swooshy whistle thing is? the thing i was talkin about just as boost came on at 1st gear n began to stuff eveythin up??
https://www.sau.com.au/forums/topic/38673-carz-t-plz-help/#findComment-783115
Starts ok, idles ok - hmm weird.
If you heard a whoosh sound from the left hand side, I would be checking all the pipework from the turbo to the manifold - if a pipe has popped off, it will also cause overfueling - still, its strange that it idles ok. Low vacuum too, hmm, may be cooler pipework, may also be turbo (oil seals/turbine side). What doesnt seem to make sense here though is that oil burning in the exhaust will cause white/blue smoke - black smoke is more fuel.
Also, massive blow by??? if uyour not running big boost and big power next place is often ringlands/pistons/bore. As ringlands go, the exhaust gasses pressurise the crank case so much that the dipstick will often pop out, and cause oil to be sprayed around under the bonnet.
How do you know it is blow by, and not something else, like a turbo oil feed?
If you have degresed, try spraying kero around the engine bay, then idle the engine for a while (keep an eye on the oil level and oil pressure at ALL times while the engine is running - if it drops, shut down the engine.) Have a look around the engine bay - the kero will mean the oil tends to drip off, leaving a nice line where the oil is coming from.
Some things to try anyways - good luck I hope it is something like an cooler pipe. (the whole blow by thing has me a bit concerned though that its something to be wary of)
Oh, and if you have stuffed the engine (hope not), usually it is cheaper to just buy a new second hand one complete then rebuild the original.
https://www.sau.com.au/forums/topic/38673-carz-t-plz-help/#findComment-783176
hey thanks for the info steve.
I'm guessin its blowby cos alots of oil mist has been sprayed from the BOV, and when i took off all the pipes, there was a decent amount in the intercooler....
and i'm also pretty sure its black smoke, but my dip stick has never blown out.
but i'll check out the cooler pipes tomorro...couldn't b f't right now so late n stuff,
It doesn't actualli idle ok...sometimes it drops up n down around 500-600rpm...sometimes just stay at 550rpm.
oil pressure n levels are good.
just some things to ask ya...
when i degreased the pins in the AFM, does it cause damage? i've done it be4 without problems, but i used a differnet brand today, but doesn't have warnings of that sort on the can.
And how can i check if its the turbo oil feed? would i need to take it to a turbo place so they can rip it part or can u tell form the outside?
Thanks alot man
https://www.sau.com.au/forums/topic/38673-carz-t-plz-help/#findComment-783496
To check any oil leak, clean it, brush on kero, then run the car for a while and look for oil leaks.
For cleaning electrical contacts use either non residual brake cleaner, or an electrical contact cleaner - degreaser may leave a residue, so best not to use only that. My favourite is brake cleaner.
And fit that catch can as soon as you can:) By the time it gets to the BOV, the intercooler is doing stuff all, just warming the air;) plus all the oil and crap that is going into the cylinders is not doing you any favours. You can also block off the pcv at the same time, so all crank case gasses have to go through the catch can. Make sure the catch can is baffled or similar, otherwise they dont tend to do much.
https://www.sau.com.au/forums/topic/38673-carz-t-plz-help/#findComment-783843
yea man...
i got the catch can..its installed already. but i seriuosli have no fu ken idea wots the use of it. surely i can see that it'll hold all the oil, at least that won't be coming back into the engine, but the gases are still going.
It came with this plug thing, very similar to a BOV return pipe plug.
if i plug that in.....does that mean, i will use only one hose (cam covr to catch can) then use one of those little filters on the catch can? if it is like that.....i have no idea how the filter is going to fit onto the can....i've got one of those 15mm cusco cans. i dunno wots inside.
Anywways i'm hoping i just done a piss poor job puttin the pipes back on. will go n jack the car up now.....Thanks for all the help fellas. get back to ya's
https://www.sau.com.au/forums/topic/38673-carz-t-plz-help/#findComment-783870
hey fellas...
yea i was just cooler pipes hehe sik sik...
hmm....but where do u guys put u'r catch cans.....???
the only place i can put it with the hoses that it comes with..is behind the air filter...but it pushes the filter up n forward...so its crap.
But yea Thanks for everyones help...
really appreciated..
https://www.sau.com.au/forums/topic/38673-carz-t-plz-help/#findComment-783953
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
