Full handbreak leaver/handle unit to suite a R33 GTR Series 1 and 2
Good working condition. Asking $50.
Pickup from North Sydney or can post out anywhere for an additional $10.
PM me or post here if interested.
https://www.sau.com.au/forums/topic/386783-r33-gtr-handbreak-leaver/
  • 4 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
