Hey guys, ive just been told that the steering rack mounts or somethin to that discprition are almost worn out causing a flat spot in my steering in my r32 gtst.
Has anyone had this happen to them, if so, how much to fix?(or estimates of those in the know.)
Also i have been recommended by friend of myn to try and source a r34 gtt rack, as the steering will be much more direct, has anyone heard this. also does anyone know were to source one of these, and the estimate of cost?
thanks
https://www.sau.com.au/forums/topic/38703-r32-steering-rack/
hi I've had the whole steering rack and all tie rods replaced in my car and its not that much of a hassle. Can you be a bit more specific as to what is worn?
Personally i've changed both my tie-rods in my '93 32GTS-T as I wanted everything to be absolutely perfect. If you're getting vague handling then its most likely worn upper control arm bushe's, tie rods etc. Nothing unusual for a used car.
I doubt a 34 GTT rack would fit but you never know......
https://www.sau.com.au/forums/topic/38703-r32-steering-rack/#findComment-794270
thanks guys.. well sorry i was vague with description, the guys aligning my wheels the other week were vague too..
all i know now is, when i went to get rego check, it passed, and he tryed moving the bushes etc near the wheels and they were all fine, so my mechanic mate(cant do pink slips etc) said its the steering rack bushes(the whoel rack shoudl be replaced)...
he seems to think that it would be better fitting an r34 for better steering, all i wanted to know about these things are will that require same power steering pump pressure as r32, and will it fit :s thanks ofr your help tho guys much appreciated.
hayai32 - was that a brand new rack? or 2nd hand sourced from wreckers...
https://www.sau.com.au/forums/topic/38703-r32-steering-rack/#findComment-795936
ok few answers as i was into a mechanics today...
basically r34 rack will not fit.. totally different (damn he had to tell me this, as now my DIY buddy has the idea that we should just change cross member in my car etc so i may fit the r34 rack :S )
anyway.. 2 wreckers wanted $350, and $400 for the rack, another place said dont have one but $130 for it hwen they get one.. they said should be one on a half cut coming next week, so i put my name down for that. egg silent. thanks for your help
https://www.sau.com.au/forums/topic/38703-r32-steering-rack/#findComment-798713
i have a r32 gtst hicas rack ill sell for $100 plus postage... im in qld..... i cant offer a warranty cause it is from a halfcut but id say it should fine only done 68k in the half cut....thats another cheaper option for you anyway..... depending where u are freight shouldnt be too much by busfreight....
https://www.sau.com.au/forums/topic/38703-r32-steering-rack/#findComment-801326
  • 3 weeks later...
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
