I have worked in town for 2 years for a civil/structural firm alexander browne cambridge on turbot st.  Now working down the coast for Knobel Consulting (mainly designing subdivisions & siteworks developments).
JL, who do u work for ?
I am guessing you work for Civdec JL?
  • Replies 46
Ahhh, didn't read that one. I pretty much work for myself. I work for Contourables (consists of me, my chainey, and Glenn), but Glenn is very close to retirement and I will take over from there. Pretty much have already, the only input he has is to sign the pay cheques and check the TAB results. Although, I am contemplating doing the civil eng. degree, just to get out of the sun. I am pretty much 3/4 the way through it anyway from the Surveying degree and partly finished IT degree.
Most of our work comes from Civdec. Again, its nearly all subdivisions, with the occasional main roads job thrown in.
Sounds like u have a pretty good setup ey. Did u do the surveying degree at USQ?
Do you have much work down the coast at the moment ?
Where I am at now alot of it is within Gold Coast/Tweed area. Still getting to know the consultants which we work with, as where I worked in town was mainly around Bris. I will keep an eye out for u...
