Hey guys,
I have a 98 r34 GTT and my boot won't open! You need 2 people to open the boot pinch.gif When i lift up the lever from the driver's side, it unlocks the actual boot, but it wont lift up by itself unless another person is there to lift it open.
My dad's helped me out and narrowed the problem down to those hydraulic arms inside the boot. He says they're not strong enough anymore to lift the actual boot up when unlocked.
Does anyone else think this is the problem, and if so, do you know where i can get replacement parts for it so my boot will actually open and approx how much it'll be? lol
There's 2 of these hydraulic arms in the boot that lift it open. (sorry if it's not an actual hydraulic arm, but i don't know what else to call it) whistling.gif
thanks!
https://www.sau.com.au/forums/topic/387402-r34-gtt-boot-arms/
they are actually gas struts, they can leak over time , guessing the car is around 12yo+ so realy it isnt doing to bad.
best bet would be to look in the yellow pages and find someone in your area that re gasses boot/tailgate struts. this is alot cheaper than getting new replacements. also of these kinds of companys have a mobile service and can come to u at home or work..
Hope this may be of some help... post back if u fix the problem!
Mick
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
