Speaking of clamps where do you get some decent intercooler piping clamps?
I just use standard Norma style worm clamps. If youre pipes are blowing off it means there are other issues, not enough ridge to stop them poping off or oil on the rubber?
Mine holds over 40psi when hot with no issues now.
  • Replies 65
Nice meeting everyone, Sorry to have ditched after we got to the final bbq area, We didnt bring any meat or anything, was working on the sil til 2am the previous night. So we decided to go back in to town to get some food and planned to come back, But my mates were bitching so we went home!
Anyone else full on scraping like f**k on the last set of twisties before the end point?
Scotty - We were spewing we didnt get to see you gun it in your car, we were at the back of the pack and because I had no idea where we were going didnt want to get in to a different lane to catch up! shattered, Id expect world war 3 to happen when you put your foot down eh?!!!
My favorite cars of the day was the silver m35, with the big grill and arx over fenders. The whole care from top to bottom is just did right!
And the 260rs with the exhausts coming through the rear bar! Such styling on that thing!.. Did you buy it like that?
Nah i dont have problems with my pipes coming off, but some of the clamps are twisting and looking a little worse for wear. They still hold really well but i'd like to know where i can get some replacements, just cos i like having things immac. :-D
That silver M35 was real mint, clean and just real pretty. My 260Rs exhaust through the bar was part of the package. I bought the car like that, you just cant stand too close to it cos they stick out so far that you'll burn your shin on it. LOL I fell in love with the kit the moment i saw it. :-P
I absolutley love the rims and the ride height on your car, even the sparks out the ass end when you bottomed out was great to see. LOL Its a shame i missed out on getting some nice pics of it.
Thanks for the compliments bLaQ.bOi! It's an M35 Axis Autech, hence it all come like that from factory.
I too loved the ride height of your M35 and rims! Looks a treat! BUT I must admit, driving behind you at time I thought you were going to bottom out or shred your rear tyres on the wheel arche lips, just a bit more camber I reckon.
Thanks THRLLR! I must say, your 260RS is one mean and awesome looking family wagon > twin turbo, gtr drive train, manual, recaro seats, fully optioned, etc.... Now thats a family coon with attitude!
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
