Hi guys , stripping all the parts off my 32 after someone wrote it off. :( Was one of the cleanest 32's out there that I imported from HKS in Japan.
The car prior
The car after
Everything is going ,
Interesting parts -
POWER FC with Hand controller and FC Hako Usb conection and tuning software ( ECU Also has a RacePace tune on it) $850 delievered
Splitfire Coilpacks (Around 3000K's use) $450 delivered
Bride replica seat with rail $400 (Would preffer pickup)
HKS Speed limit Defender $150 delivered
Nismo 320KMPH cluster$ 200 delivered
Bee*R Rev limiter $200 delivered
Tein Winding master Coilovers $800 bucks (They are amazing)
Aluminuin radiator $300
HKS SSQV Bov - make me an offer
HKS mushrooms make me an offer
Also have Cusco Controller arms , strut brace , braided brake lines and heaps of other stuff if you want to come past one day and check them out .
+ The rest of a '93 GTR including all switches, door trims , dashboard , N1 bootlip , pods and spoiler. - EVERYTHING IN ABSOLUTE PRISTINE CONDITION.
Engine has around 145- 150 thousand K's , made 265RWKW @ 14 psi with intake , exhaust , coilpacks and power FC.
Any parts that you need , let me know and ill tell you if i have them .
Any pictures that you guys need , ill take , just very bust at the moment with work.
My Mobile is 0434112724 , if i dont asnwer im at work , but feel free to send a text and ill get back to you ASAP.
Make me an offer.
Thanks guys.
EDIT:
Parts that are gone :
Dashboard
Nismo Cluster
gauge cluster
AC controller
N1 Bootlip
Drivers STANDARD seat (still have the Bride)
Both Door trims
https://www.sau.com.au/forums/topic/387691-wrecking-r32-gtr-vic/
  • Replies 48
Posted Images
front brakes?
Yes , non v spec calipers , RDA rotors and A1RM pads
500 all up.
Ive got a potential buyer for the whole car though , so ill let you know tommorow .
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
