After weeks of talking the meet'n greet cruise is a GO!!!:yes:
12/2/12
>>>>READ: IF YOUR GOING TO BE A TOTAL TW*T AND THINK YOUR KEN BLOCK/RHYS MILLEN OR START DRAMA AND GET THE UNWANTED ATTENTION OF THE POLICE DO NOT EVEN BOTHER SHOWING UP. WE DO NOT WANT YOU!!! THIS IS A CHILLED DAY AND JUST WANNA MEET UP HAVE A CHAT, GET TO KNOW EACH OTHER, TALK ABOUT CARS AND HAVE A GOOD TIME. IF YOU READ THIS AND STILL THINK YOUR KEN BLOCK/RHYS MILLEN, I WILL NOT HESITATE TO CALL THE POLICE MYSELF<<<<
Kotara home makers center infront of supercheap auto/howards storage world area at around noonish no rush, then go for a cruise on a destination that everyone can agree on: Tuggerah/erina/the entrance/gosford etc etc
My close mate chris will be there with a DSLR taking photos, he will ask to take pics (he's not rude) of your car, if you do not wish just say so =]
Wanting to keep it in the grey import/JDM nissan family.
Skylines of all generations, coupe and sedan. Silvias. GTR's. Stageas of all generations. Cubes. Cefiros. Pulsars. Bluebirds. Laurels....even Elgrands i dont care If you know anyone with a JDM/Grey import nissan and they are free bring them along for sure.
Spread the word...PLEASE!!!!:rofl:
Any problems PM me.
Some nice V models if found from the US V series (G35) meet.
http://fatlace.com/cars/slammedsociety/g35-sedan-showcase/
https://www.sau.com.au/forums/topic/387805-the-2012-meetn-greet-is-go/
next one i do ill give plenty of notice and help find you some place to stay. this one is just to see how many cars turn up so i can get an idea of what the skyline/import community is like
im not sure how many ppl are going to come up to newie from syd for this, im working on the 11th and have a 1 day weekend so ill have to wait and see whats going on as its my birthday on the 10th may be doing stuff with family on sunday.
Thanks, but I was really just refering to the distance, not the timeframe you gave.. As much as I would like to attend, I don't think I can justify the cost and time to get there, and I don't think there are really enough owners up this way to organise anything locally.
Hey Greg, Maybe you should make a run to brisbane/GC when there is a meet and greet.....we had a couple at the end of last year....
Yeah, that might be more 'do-able', although it is still 2 days drive (or one very big day) each way. Whenever I travel to Brisbane, I usually fly.. I haven't driven to brisbane for a while now..
I will keep an eye out for when something is planned and see what I can manage.
Hey Naz was that you i was talking to outside dan murphys at west gosford the other day?
I dont think so, only times i go to Gosford is when im going to Blue Tongue stadium. I was there a couple of weeks ago but wasnt outside Dan Murphys.
  • 3 weeks later...
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
