Thanks titan just bought the controller that my tuner recommended found 1 for a decent price so i jumped on it :thanks:
basic open loop or full closed loop control, will require dyno time to setup all the fiddly settings to get closed loop working 100% but once set it takes care of boost drops/spikes itself.
Im putting your predictions to the test mate im gunna get yavus to push it as much as my fuel system can cope but safely of course haha :worship:
On flex too? ;) Man I would be tuning on caltex flex if it was available at more than 3 servos in the freaking state...
I rekon on flex and 30psi you would be waking up to a wholeee newww wooorrlldddddd :3some:
push the thing up there anyway, see what happens :P
1/4 of the price of a profec as you only need a basic MAC valve, doesnt require any extra gadgets in the cabin, does gear specific boost/ramp corrections, intake temp corrections (eg intake temp 80c = reduced boost), water temp corrections (engine water temp of 110c = reduced boost)
why you wouldn't use it is beyond me.
yeah on the flex :yes: im lucky that 1 of the 3 servos is a km away from me just dunno if the 850's will take 25-30psi with E85 but ill have to wait and see huh.
You are gunna be the 1st 1 to know my results Jase :P
:rant: i already bought it which sux now that you put it like that too
Haha love it! cant wait
If caltex does a better roll out of that stuff ill be onto it quick smart! Somebody needs to contact their marketing dpt and inform them of how immensely popular that crap is with performance folk
I would hate to cart my car all the way to wakefield for a track day only to run out of flex half way thru the day :(
Whats an HKS controller worth?
Id sell it and buy the G4 solenoid. Its dirt cheap ($100NZDish) and works a charm!
Closed loop boost control is fantastic. As mentione can take some setting up, but once it works its brilliant.
I wired mine into the stock boost control solenoid loom in the bay, then just set the input. Done.Took 10 mins to install :)
But of coruse, if its all up and running.. leave it be.
Edited by gotRICE?
Think the EVC 6 is still around $550 - $600+ brand new :blush:
Im definately ditching the HKS bought my profec already though :ph34r: might give yavus a call see what he says
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
