Selling a fibreglass R34 GTR Spoiler with high wing stands (about 20cm tall) approx 6cm higher than the standard GTR wing.
Looks great and has adjustable wing, unpainted and brand new.
Fibreglass is really light weight.
Price: $550 ono
Pick up from Epping, Vic or organize courier if you want. PM if interested
Thanks
https://www.sau.com.au/forums/topic/388201-r34-gtr-spoiler/
The fibreglass is actually quite good, and its a really good replica of the real spoiler. I havnt got anymore photos because its at my panel beaters shop. I can get more for you this week but your more than welcome to come have a look first..
https://www.sau.com.au/forums/topic/388201-r34-gtr-spoiler/#findComment-6189313
  • 1 year later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
