Hey people, I was wondering if someone can tell me the differences between R32, R33, R34, and N1 spec GTR turbos, and how to tell them apart?
Seems that the GTR I bought off Andrew last year has neither near new, nor R34 turbos - they are completely stuffed - oil seals gone, heaps of play, and nicked wheels, so I'm looking for another pair.
Seems there are some well priced near new pairs out there, but I'd like to be sure of what I'm getting since I've been burnt once already.
Also, what are people's ideas on N1 vs 2530 vs GT-SS turbos, given that I liked the spoolup on the current turbos (usable boost at 2000, full boost of 1bar at 3200), and that I'll probably do some mods over time (like Power FC, dumps, etc), but don't want to do any internals (except maybe cams - I already have adj cam gears)?
Any help would be appreciated before I splash out next week on a new pair to rescue my car from the workshop (I've been pining for 2 weeks already :) )
https://www.sau.com.au/forums/topic/38822-gtr-turbo-info-needed/
if you included markings it wouldve made my job easier!!!(being a slow typer!!)Anyway...here....
model part number Turbo type A/R
Bnr32 14411-05U20 T3 0.42
Bnr32 nismo 14411-06U00 T04B 0.42
Bcnr33 14411-24U00-4 T3 0.42
Bcnr33 N1 14411-24U10 T3 0.42
Bnr34 14411-AA300 C100 053
Bnr34 N1 14411-aa401-3 C106 0.6
I have heaps more info....what else you want to know??I have 2 BNR34 turbos in the shed also :)
Cool, thanks for that ylwgtr2...helps a lot to figure out what's what...
I know that the N1's are non-ceramic, but what about the standard R34's ?
Are the 2 you have stock R34 or N1?
Hey DeanJSL, yeah...seems that for what I'm looking for, a pair or 2510/N1/GT-SS should suit fine.
As far as I'm aware The only difference between the R34 N1 and the R34 N1 NUR spec Turbos is that the later came with Nismo extensions.
There were only 100 R34 nur spec. GTRs produced.
I have an as new set for sale at the moment with the Nismo dump pipes.
$3750.
Phillip
(07) 40698449
Ok. I was offered the dumps with them for a bit extra, but I'm a bit cash deprived at the moment , especially since I might yet be up for more engine repairs (the turbo replacement is stage two of the fault finding).
I think dumps will be the next thing to go on my car, I know what a difference it made on my last car.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
