hey guys im selling R33
not in a hurry to sell just want to see what i can get for it being a swap or cash or both
The car is a perfect sleeper was on 19's deep dish but didnt want to attract cops so now its on stock S15 wheels
125,000 km's
Manual (short shifter)
GT35/40 Turbo
Fuel rail
Cooler
Screamer
battery is now in the boot
ALOT TO MENTION
Reg is currently suspended due to the exhaust being to loud i have the original at home and will give to the buyer to put on
reg expires in mid February
*****DVD player is not included as it was draining the battery while the car was switched off so i sold it
PM me with offers and contact numbers i will be checking constantly
https://www.sau.com.au/forums/topic/388528-vic-r33-gtst-1993/
  • Replies 51
Posted Images
MODS
GT 35/40 Turbo
All Braided lines
DBA Slotted Disks
Wallbro 255 fuel pump
3" exhaust from turbo back
5Zegen 4" exhaust
Top mount Extractors with screamer pipe
30 mil turbo smart external wast gate
Rajab front mount cooler
Custom Radiator
Greddy copy plenum
80 mil Throttle Body
Heavy duty clutch
Pedders Springs
k-mac shocks all around
Adjustable Cam Gears
Nistune Computer
Siemens 850cc Injectors with fuel rail
Engine Rebuilt standard specs
short shifter
turbo timer
If it has to go through vicroads there is a hell lot of a lot of money to spend there. Good luck with sale though!!! Good setup there.
it doesnt have to go through vic roads its just got a suspended reg u just need a road worthy and thats it reg doesn't expire till late feb :)
forgot to mention the car has A/C it hasnt been disconnected and wont be since the weather is getting hotter everyday
this car is a perfect sleeper dose and screamer alot of mods real head turner and comments from people that dont expect it to be the way it is cause of its looks ;-)
open to swaps and cash my way depending on the car offered to me or $10,000 including the original exhaust for RW
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
