Mate it varies quite lot depending on suspension setup, spring rates, damper settings, power, weather, track temp blah blah.
I've got 595 RS-Rs and run those at about (err memory failing me as it's been a while) I think around 36-38psi HOT, so starting temps around 32-34psi but that's an on S13 so it's lighter.
Also, if they are anything in the 595 range other than RS-Rs then the numbers will vary too as the RS-Rs are the softest compound in the range.
People here can help you take guesses but ultimately the best way to find out is 1) Call Federal and ask them what they recommend for your car in track conditions (you did post in motorsport so I'll assume you're talking track pressures) and 2) head to the track and start testing. Take a portable compressor with you, get one if you don't have it as you will need it. A good tyres pressure gauge if the compressor doesn't have one, and ideally you also need a pyrometer to measure tyre temps across the tread face as soon as you come in from a session.
I am a budget racer, for fun only, so I don't have a pyrometer and just keep tabs on how the car feels at different pressures and how the tread is wearing.
It not only varies for the items listed above but also due to driving style, how much you care about tread wear versus lap times etc etc.
Get out there and enjoy yourself, you will soon learn at what hot pressure the car/tyre/suspension combo is most happy.
hmm... i think RSR's should be run at lower pressures... maybe around 28-32 HOT... 595s slightly higher 30-34 HOT.... That's for getting max grip, but you will trade off some handling... Higher pressures makes the car less grippy but more responsive... if your starting out, good idea to use higher pressures first... better handling will do you more good than grip... once ur completely happy and confident with the handling at the limit... drop the pressures... you will notice the increase in grip...
If u dont have a temp guage... use ur hands.... if ur pressures are way out of whack... u can feel it... 10+ deg cel is easy to feel with ur hands...
ie. If the temperature on the face of the tread is L60 C75 R55
you will easily be able to feel the centre is friggin hot and cooler on the edges.... clear indicator to drop ur pressures....
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
